I accidently chose Nebula for my NWA5123-ACHD. I want to change from Mgmt to Compatible
I registered a Nebula account and registered the AP there0
When I try to take the AP out from Nebula. It says the device is not registered. How can I solve this? I have reset the AP. It comes back as Mgmt Nebula Off-line.0
Hi @GoldWare,
The Mgnt means that the AP is using the same firmware as the controller and the compatible means the AP is not using the same firmware as the controller. As your screenshot, the NWA5121-NI is limited in version 5.10, but the NWA5123-AC HD can be up to last firmware version, so the NWA5123-AC HD shows Mgnt. in the controller.
If you have problem to let the controller manage the AP after unregister it from the NCC, please reset the AP to default and check again if the AP can be manged.
Thanks.0 -
See my earlier comment:
Hi @GoldWare,
To let the AP be managed by controller, you don't have do to any registration.
When you registered the AP to Nebula, the AP became to cloud mode and didn't show on the controller. However, as your description and screenshot, the AP was not registered in the NCC and found the controller but failed to online. So, please check if the AP got an IP address and SSH to the AP to check if it can ping to the controller.
If all above is no problem, please execute below commands to check AP status and share to us.
Router> show hybrid-modeRouter> show capwap ap ac-ipRouter> show capwap ap info0 -
I will try to do this.
So off-line doesn't mean off-line for real? So why can't any devices connect? Or can they but I can't see this?0 -
I got:
Network error: Connectoin timed out. (Putty, SSH)
It doesn't answer to ping either and the Zyxel One Network Utility can't find it either.
However Zyxel ONU does find the Zywall110 & the NWA5121-NI0 -
Hi @GoldWare
Thanks for helping check the AP status. The offline means the AP can't connect to the controller but if the AP can get IP and provide the wireless service, it's workable. So, as your description, the AP seemed to get an IP address, but failed to access via SSH, ping and ZON.
Would you check the DHCP table of the DHCP server, and ping from the DHCP server if it's available to check the AP did get the IP address. If it's not able to get an IP address, please try to reset it via hardware reset button again.
If above steps are not helpful to recover the AP, please RMA it.0
- 441 Beta Program
- 210 Nebula Ideas
- 539 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
