Cheap Gigabit Switch With VLAN Capabilities
On a shoestring budget, I have a number of device that support VLANs that I'd like to segment, plus I'd like to open a wifi network with captive portal secured away from my main network.
What I need, though, is a cheap gigabit VLAN configurable switch. Where should I be looking for such an item?
Realistically, I only need 4 gigabit ports (uplink) and the others can be 10/100. Any switches like that?
Hi @Garaofsand,
Welcome to Zyxel Community!
Regarding your requirements, I'll recommend two devices for your reference.
GS1200-8HPv2 a pure standalone switch which supports 802.1Q VLAN and links of 10/100/1000.
GS1920-8HPv2 a Nebula flex switch that also meet your needs and support Nebula Control Center which is more convenient to manage & monitor anywhere you are.
Hope it helps.
Jonas,0 -
i got this,..Garaofsand said:On a shoestring budget, I have a number of device that support VLANs that I'd like to segment, plus I'd like to open a wifi network with captive portal secured away from my main network.
You didn't really say how many ports you needed. . . .These days, I wouldn't even mess with a switch with 10/100 ports,unless you're buying something used.I'm assuming that you don't need power-over-ethernet. . .GS1200-8 (without the HP). . . $40 or so on-line. 8 ports, gigabit, managed.GS1900-16 $85 or so on-line. 16 ports, gigabit, managedThough I've seen *USED* Cisco Catalyst 2960G gigabit switcheson ebay in the $50 range for 24 gigabit ports. . .0
- 588 USG FLEX H Series
- 476 News and Release
