Cheap Gigabit Switch With VLAN Capabilities
On a shoestring budget, I have a number of device that support VLANs that I'd like to segment, plus I'd like to open a wifi network with captive portal secured away from my main network.
What I need, though, is a cheap gigabit VLAN configurable switch. Where should I be looking for such an item?
Realistically, I only need 4 gigabit ports (uplink) and the others can be 10/100. Any switches like that?
Hi @Garaofsand,
Welcome to Zyxel Community!
Regarding your requirements, I'll recommend two devices for your reference.
GS1200-8HPv2 a pure standalone switch which supports 802.1Q VLAN and links of 10/100/1000.
GS1920-8HPv2 a Nebula flex switch that also meet your needs and support Nebula Control Center which is more convenient to manage & monitor anywhere you are.
Hope it helps.
Jonas,0 -
You didn't really say how many ports you needed. . . .These days, I wouldn't even mess with a switch with 10/100 ports,unless you're buying something used.I'm assuming that you don't need power-over-ethernet. . .GS1200-8 (without the HP). . . $40 or so on-line. 8 ports, gigabit, managed.GS1900-16 $85 or so on-line. 16 ports, gigabit, managedThough I've seen *USED* Cisco Catalyst 2960G gigabit switcheson ebay in the $50 range for 24 gigabit ports. . .0
- 347 Beta Program
- 2.1K Nebula
- 115 Nebula Ideas
- 77 Nebula Status and Incidents
- 5K Security
- 44 USG FLEX H Series
- 246 Security Ideas
- 1.2K Switch
- 64 Switch Ideas
- 900 WirelessLAN
- 33 WLAN Ideas
- 5.8K Consumer Product
- 204 Service & License
- 326 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.8K FAQ
- 831 Nebula FAQ
- 401 Security FAQ
- 219 Switch FAQ
- 190 WirelessLAN FAQ
- 45 Consumer Product FAQ
- 136 Service & License FAQ
- 71 About Community
- 61 Security Highlight
