UAG4100 LAN2 usage
I have a UAG4100 connected to two lans. The final client lan, lan1 works as expected. However I'm not able to reach the UAG4100 from lan2. I'm able to ping from the UAG4100 to lan2, but not the other way around. As far as I can see both lans have similar configuration:
What am I missing here?
Thank you,
Regards,
Helder Guerreiro
Thank you,
Regards,
Helder Guerreiro
Hi @hgg,
Device access from Lan2, the packets should hit the security rule#7 "from Lan 2 to Device". The rule is proper setting from your screen shot, it could be something wrong on other configuration.
You can check the zone setting first on "Configuration > Object > Zone", make sure "LAN2 zone group" have member "lan2".
Hi @hgg,
Can you do one more test, ping from lan2 subnet host to lan2 interface IP, and packets capture on lan2 interface.Here we would like to know does the UAG lan2 receive the packets from lan2 subnet host.
If it is still fail to access from lan2, please send me your configuration file via private message.
CLI packets trace:
Router> packet-trace interface lan2
- 441 Beta Program
- 293 Service & License
