USG310 - 4.62(AAPJ.0): Wildcard FDQN seems not to be working for routing!
cfts_ea
cfts_ea Posts: 19 image  Freshman Member
edited April 2021 in Security
I have been trying to get Wildcard FDQN's working in routing with mixed results right now I'm having to list domains and sub-domains and it's getting quite tedious.
for example, I wish to allow/redirect all traffic to *.fbcdn.com to another link, I have this working listing each and every domain/subdomain, however, the wild card option seems not to be working.
I have made the appropriate wild cards but as said these seem not to work, Is it possible for someone to advise how I'm supposed to use this feature?
Best Answers
    edited March 2021 Answer ✓
    Ok something to keep in mind about Wildcard FDQN vs non-Wildcard FDQN as non-wildcard are looked up by the USG and Wildcard FDQN are found by DNS lookups done to the USG or though the USG so if a client uses say Firefox with DNS over HTTPS the USG will not see the lookups.
    So you got clients connect by VPN to the USG?
    Can you not run a bind server where DNS is in the clear?
  • cfts_ea
    edited March 2021
    a small correction: for example, I wish to allow/redirect all traffic to *.fbcdn.com to another link, I have this working listing each and every domain/subdomain, however the wild card option seems not to be working.
  • cfts_ea
    edited March 2021
    Thank you, all DNS lookups are routed through VPN then to a SDNS (DOH) server on our side, So I'm guessing they're no way for me to resolve this easily.
  • cfts_ea
    edited March 2021
    Thanks, I set up a raspberry pi with a Commercial grade VPN, Pihole and DNSCrypt works a treat, complements the USG very nicely.
    https://github.com/pi-hole/pi-hole/wiki/DNSCrypt-2.0
