Fans GS1900-24HP / Ventilateurs GS1900-24HP
It thinks the fans has stopped.Do you see the fan really stop? or just false alarm?Also in the status screen it will say error because the middle wire is not used. Only the + and -.If you remove the middle wire on your new fan, I think it is normal that Switch shows error, or you just want to find a way to disable the error message? 🤔0
- 588 USG FLEX H Series
- 477 News and Release
