ZyWall USG 50 L2TP Remote Acces (Server role) behind Asus RT-AC57U as DMZ but can not connect
Hi all,
I seen all the ytd videos about Zyxel USG/VPN behind NAT config, but there is always one or two things which is not in my ZyWALL USG 50. e.g. : Quick Setup -> You have 3 options on the video, cool, but I have only 2, and yeah, I wish to setup the 3rd one, L2TP VPN. I wish to access my home network from 2 iOS device.
I just copied all the settings, step-by-step, (except IP addresses) from a working enivroment where the device is Zyxel VPN 100, and I can connect from my iOS built in client.
Zyxel USG 50 - Firmware 3.30(BDS.9)
Boot module: 1.17
Topology:
(Internet) dynamic but public IP from ISP (same on myip.com as on my router WAN IP) --> Asus RT-AC57U pppoe -> static IP in DMZ zone -> USG50 WAN
Any idea more than appreciated.
Regards,
Peter
Boot module: 1.17
Topology:
Regards,
Peter
Hi @pepev82,
For L2TP settings you can take following KB article as reference;
https://kb.zyxel.com/KB/searchArticle!viewBlob.action?attOid=14517
The steps in the KB article, is the equivalent of the 3rd option in the Quick Setup.
Please kindly try to configure your USG50 as in the article.
After creating L2TP option, you can apply NAT settings.
Dear @Zyxel_Can
Thank you for your answer.
Since posted my question, i just go forward to look around on Zyxel forum.
Then i found @Zyxel_Emily 's answer to someone else.
https://community.zyxel.com/en/discussion/comment/15194#Comment_15194
where she said:
"ZyWALL USG 50 does not support L2TP server behind NAT.L2TP server behind NAT is supported since firmware version 4.11.
You may consider USG60/USG110/ATP100/USG FLEX 100 which supports this scenario."
So I just sold my USG50 and hopefully soon i will buy a Zyxel USG60 device.
Certainly, I just saved that PDF which could be very useful to setup my new device.
Best wishes,
Peter0
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 84 About Community
- 87 Security Highlight
