USG FLEX 100 and NXC2500 Port Forwarding
hello everybody,
maybe someone can help me with my problem:
I need to configure a port forwarding rule for one wired computer on left side (office-pc)
Office PC IP-Address: 192.168.1.101 and port 4712 incoming needed
how do i pass this port through usg-flex-100 and nxc2500 to office-pc?
wan-ip is static on usg-flex-100 >> goes to lan2 172.20.0.1 >> to nxc2500 goes to port 2 192.168.1.xxx
i've tried with nat / snat on usg-flex-100 and also on nxc2500 but i've not come to a working solution...
is this solvable? or do i need a network redesign?
regards, shortl
Hi @shortl,
Can you please configure as following;
1 – Create address object for your wan1 IP and Office-PC;
2- Add NAT under Configuration > Network > NAT
3- Add Policy Control rule under Configuration > Security Policy > Policy Control
Here’s similar topic, please take as reference;
Best regards.
hi zyxel_canthx for your advice, but maybe my visio was not precise enough:regarding to your help >> pls take a looklan1 interface on usg is not connected to any switch or computer, lan1 interface was only for test purpose, so pls ignorewhole traffic (computers, wlan-ap....) goes through lan2 interface on usgso office-pc is connected to switches and the main switch uplink goes to nxc2500 (cause of captive portal redirect on controller for mobile clients)from nxc2500 to usg via one wire via interface ge1 on nxc2500 to interface lan2 on usgi think your screenshots are taken from usg settings, right?do i also need to make some nat-rules on nxc2500?i've also activated firewall on nxc2500, some rules more needed?regards, shortl0
thx man, that was the trick, all working nowregards0
- 217 Nebula Ideas
- 578 USG FLEX H Series
- 297 Service & License
- 474 News and Release
