Routing in vti
nikita92
nikita92 Posts: 7 image  Freshman Member
edited April 2021 in Security
Kind, I ran into a routing problem. There are two Zywall ATP 500, it is necessary that the clients who are on Zywall A when accessing certain sites, let's say "tut.by" went to the vti tunnel and went to this site through the Internet provider on Zywall B. I sort of set it up by logic, well, it does not work, can you tell me how to do it better and more correctly. I attach two configs to the letter. Thank you so much. I really hope for you.
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @nikita92,
    You forgot to add the configuration files.
    Can you please share ATP500s settings and let me check for you?
    Best regards.
  • Zyxel_Can
    Hi @nikita92,
    Can you please try to configure as following;
    1- Create FQDN Object for tut.by website;
    2- Create Policy Route for VTI;
    Best regards.
