USG20-VPN WITH NAT AND VIRTUAL IP
Hello!
I have a USG20-VPN factory restored, and ready to be configured!
I need to install it in a already built network (192.168.1.0/24) because I have some devices that I want to reach with SSL VPN.
I try to explain what I think to do:
I attach an image to explain the situation:
- assign virtual IP to the USG
- NAT that IP to the real IP (internal network of the USG, for example LAN1)
- create rule to let user connect from the primary network to that IP
- configure VPN SSL to reach internal IP of the USG (with NAT rule from the primary modem)
If your modem router at 192.168.1.1 can do static route there is another way without double NAT.
Thank you @Zyxel_Can!
Everythings are clear!
@PeterUK: yes there is a modem router and I have access to it. What do you mean with another waY?
Instead of SNAT 192.168.0.31 from 192.168.1.30 or with virtual IP's you static route on the modem router at 192.168.1.1 for 192.168.0.0/24 to 192.168.1.30 you then make a routing rule with Use IPv4 Policy Route to Overwrite Direct Route checked to go from incoming LAN1 to next hop gateway 192.168.1.1
- 241 Nebula Ideas
- 6.8K Security
- 761 USG FLEX H Series
- 382 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 323 Service & License
- 522 News and Release
- 100 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
