Connecting to Local NTP server with usg flex 500
AlexRiviera
AlexRiviera Posts: 14 image  Freshman Member
edited April 2021 in Security
When trying to connect to my local ntp server the zywall shows a timeout error. Connecting to ntp servers in the internet is working. Other devices as switches (zyxel) or PC’s can connect to the local ntp server. Is there a known issue that the zywall is not able to connect to local ntp servers?
«1
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @AlexRiviera,
    I tested this symptom in our labs it works normal.
    Can you share some information with us;
    1-    Do you have route to your internal NTP Server?
    Can you test with following path;
    Maintenance > Diagnostics > Network Tool > PING IPv4
    2-    Did you try to disable your NTP Server’s firewall or open port for NTP (UDP port 123)
    3-    Can you clarify that related service is running on NTP Server?(e.g. Windows Time)
    4-  For troubleshooting purposes, can you capture packets when syncing Time with NTP Server?
    For that you can find the following path;
    Maintenance > Diagnostics > Packet Capture > Choose Interfaces > Capture
    5-    If public NTP servers work properly but your local NTP Server can’t sync time it’s probably related to your NTP Server’s configuration.
    Best regards.
  • AlexRiviera
    Thx for your extended Feedback.
    -> Yes i get answer and 0% packetloss. So a route is there.
    Firewall where ntp server is running is "down" / not running
    Yes my Workstation as other servers are getting sync from ntp. (Tested again)
    Will do that.
    The ntp server is running on a vlan in/on ethernet (zone)  lan1. From which interface is the ntp client on the zywall making the request? WAN interface?
  • AlexRiviera
    Pakets captured, seems like the timeserver is giving an answer:
    Frame 2: 90 bytes on wire (720 bits), 90 bytes captured (720 bits)
    Ethernet II, Src: NTPServer [entry modified because of privacy], Dst: ZyxelCom_[entry modified because of privacy]
    Internet Protocol Version 4, Src: [correct IP] , [Dst: correct IP]
    User Datagram Protocol, Src Port: 123, Dst Port: 53011
    Network Time Protocol (NTP Version 4, server)
        Flags: 0x24, Leap Indicator: no warning, Version number: NTP Version 4, Mode: server
        [Request In: 1]
        [Delta Time: 0.000172000 seconds]
        Peer Clock Stratum: secondary reference (2)
        Peer Polling Interval: invalid (3)
        Peer Clock Precision: 0.000000 seconds
        Root Delay: 0.016098 seconds
        Root Dispersion: 0.045975 seconds
        Reference ID: 84.16.67.12
        Reference Timestamp: Apr  6, 2021 18:04:03.410726043 UTC
        Origin Timestamp: Apr  6, 2021 18:37:40.054865730 UTC
        Receive Timestamp: Apr  6, 2021 18:37:40.053579426 UTC
        Transmit Timestamp: Apr  6, 2021 18:37:40.053663200 UTC
    Any ideas what's going wrong here?
  • Zyxel_Can
    Hi @AlexRiviera,
     I tested put NTP Server into VLAN. It can still sync time.
     Can you try to capture packets for LAN interfaces and share in this topic?
    Best regards.
  • AlexRiviera
    Hi, thx for the answer. Well the capture is in my post above. Do you also need the request?
  • Zyxel_Can
    Hi @AlexRiviera,
    Can you capture packets from LAN interfaces and send .cap file to me by private message so I can check for you?
  • AlexRiviera
    check your mailbox please.
  • Zyxel_Can
    Hi @AlexRiviera,
    Unfortunately attached file is not readable.
    Can you try following steps for .cap file and send me again by private message:
    1 -First, start capturing packets:
    In Web GUI, Maintenance > Diagnostics > Packet Capture > Capture:
    2- Sync time with NTP Server:
    3- After synchronizing is failed go back to Maintenance > Diagnostics > Packet Capture > Capture menu and stop capturing.
    4- Download the captured .cap file and send me by private message without changing the extension.
  • AlexRiviera
    cap is not allowd in PN. So i zipped it ok?
  • Zyxel_Can
    Hi @AlexRiviera,
    In the packets you provided, I see request and reply.
    In the second cycle's response I see:
    Flags: 0xe4, Leap Indicator: unknown (clock unsynchronized), Version number: NTP Version 4, Mode: server
    Reference ID: Unidentified reference source 'RATE'
    What is the NTP Server’s operating system?
     In the RFC document section 7.4 you can see explanation of "RATE" code. (https://tools.ietf.org/html/rfc5905)
    Can you try to sync your time with a Windows Client?
    For that you have to modify following registry entries;
    Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\TimeProviders\NtpServer\Enabled = 1
    Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Config\AnnounceFlags = 5
    Then restart Windows Time service in the services.
