XGS1210-12 is overheating
zyxelboss
zyxelboss Posts: 4 image  Freshman Member
edited August 2022 in Switch
The switch has default settings, no VLANs, etc..
All 1Gb ports are connected.
In the absence of strong activity, the switch is overheating (55-70 degrees over the entire surface)
What to do?
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    In our spec. when the environment temperature is 40°c the switch cover temperature can reach to 67°c -/+ (when full loaded) 70 is still in the buffer however, did you stack the devices or installed it in the place where is lack of airflow?
  • zyxelboss
    I have to install the 2 fans to reduce my swith temperature.
  • Zyxel_Chris
    edited April 2021
    Can you share where do you install this switch?
