USG-50 Limiting our bandwidth, why?
Thanks, I'm still 25-30mb/s short of that, what would be the right appliance then, do they have a model that would be able to offer 250-300mb/s with some services? Seems like I'm going to have to return this box nowPeterUK said:The USG 40 maybe listed as 400Mb but under given test conditions with TCP and without Anti-Virus, IDP, or Content filter you should get about 200Mb
The ZyWALL110 will easily do 300Mb for TCP without Anti-Virus, IDP, or Content filter
Have you tried with ADP disabled under Security policy?
And a USG60W serve about 86% troughput of a 50MBit Line (about 43 MBit), and had the full Layer7 licenese enabled and in production.
One side effekt in performance are written down by a User in the following postRegardsChristian0 -
Thanks Christian!!!ChristianG said:And a USG60W serve about 86% troughput of a 50MBit Line (about 43 MBit), and had the full Layer7 licenese enabled and in production.
Ok I disabled everything and even more on this device even narrowed everything to one subnet de-activated everything, turned the damn thing into a router lol
Turned off the logs, the services, tested with DMZ also, nothing can go fater than 170-180mb/s, unless Zyxel support answer this forum before the end of the week we are going to return the unit and look somewhere else.0 -
Hi @BoudahXL,
Can you send me your latest configuration file via private message. let me run the performance test with your configuration file applying.
Hello Cooldia, config sent! BTW we reset-default twice the unit with blank config twice just to be sure tested Easy/Expert configs too.0
I'm sorry the issue has been resolved we have moved to a new platform, like I said last week if the issue was not resolved before the end of week we would move on to another vendor. Which we did. And the performance is on par with specs unlike the Zyxel product.1
Hi. I came across this thread, as I am currently having the same issue with a USG40. I too have a few more days to figure this out before I return the unit. Has anyone come up with a fix as to why these units are taken such a performance hit? I have a 200mb connection and I'm only getting 70mb!! I'm sorry this is not acceptable. Thanks for any assistance.0
@ FM823
Can I know did you enable any UTM feature?
What firmware version are you using?0
- 3K Nebula
- 229 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 664 USG FLEX H Series
- 359 Security Ideas
- 86 Switch Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 305 Service & License
- 498 News and Release
- 95 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
