Connecting to Local NTP server with usg flex 500
Hi @AlexRiviera,
I tested this symptom in our labs it works normal.
Can you share some information with us;
1- Do you have route to your internal NTP Server?
Can you test with following path;
Maintenance > Diagnostics > Network Tool > PING IPv4
2- Did you try to disable your NTP Server’s firewall or open port for NTP (UDP port 123)
3- Can you clarify that related service is running on NTP Server?(e.g. Windows Time)
4- For troubleshooting purposes, can you capture packets when syncing Time with NTP Server?
For that you can find the following path;
Maintenance > Diagnostics > Packet Capture > Choose Interfaces > Capture
5- If public NTP servers work properly but your local NTP Server can’t sync time it’s probably related to your NTP Server’s configuration.
Thx for your extended Feedback.
-> Yes i get answer and 0% packetloss. So a route is there.2- Did you try to disable your NTP Server’s firewall or open port for NTP (UDP port 123)
Firewall where ntp server is running is "down" / not running
Yes my Workstation as other servers are getting sync from ntp. (Tested again)
Will do that.
The ntp server is running on a vlan in/on ethernet (zone) lan1. From which interface is the ntp client on the zywall making the request? WAN interface?0 -
Pakets captured, seems like the timeserver is giving an answer:Frame 2: 90 bytes on wire (720 bits), 90 bytes captured (720 bits)Ethernet II, Src: NTPServer [entry modified because of privacy], Dst: ZyxelCom_[entry modified because of privacy]
Internet Protocol Version 4, Src: [correct IP] , [Dst: correct IP]User Datagram Protocol, Src Port: 123, Dst Port: 53011Network Time Protocol (NTP Version 4, server)Flags: 0x24, Leap Indicator: no warning, Version number: NTP Version 4, Mode: server[Request In: 1][Delta Time: 0.000172000 seconds]Peer Clock Stratum: secondary reference (2)Peer Polling Interval: invalid (3)Peer Clock Precision: 0.000000 secondsRoot Delay: 0.016098 secondsRoot Dispersion: 0.045975 secondsReference ID: 84.16.67.12Reference Timestamp: Apr 6, 2021 18:04:03.410726043 UTCOrigin Timestamp: Apr 6, 2021 18:37:40.054865730 UTCReceive Timestamp: Apr 6, 2021 18:37:40.053579426 UTCTransmit Timestamp: Apr 6, 2021 18:37:40.053663200 UTC
Any ideas what's going wrong here?0 -
Hi @AlexRiviera,
I tested put NTP Server into VLAN. It can still sync time.
Can you try to capture packets for LAN interfaces and share in this topic?
Hi, thx for the answer. Well the capture is in my post above. Do you also need the request?0
Hi @AlexRiviera,
Can you capture packets from LAN interfaces and send .cap file to me by private message so I can check for you?
check your mailbox please.0
Hi @AlexRiviera,
Unfortunately attached file is not readable.
Can you try following steps for .cap file and send me again by private message:
1 -First, start capturing packets:
In Web GUI, Maintenance > Diagnostics > Packet Capture > Capture:
2- Sync time with NTP Server:
3- After synchronizing is failed go back to Maintenance > Diagnostics > Packet Capture > Capture menu and stop capturing.
4- Download the captured .cap file and send me by private message without changing the extension.
cap is not allowd in PN. So i zipped it ok?0
Hi @AlexRiviera,
In the packets you provided, I see request and reply.
In the second cycle's response I see:
Flags: 0xe4, Leap Indicator: unknown (clock unsynchronized), Version number: NTP Version 4, Mode: server
Reference ID: Unidentified reference source 'RATE'
What is the NTP Server’s operating system?
In the RFC document section 7.4 you can see explanation of "RATE" code. (https://tools.ietf.org/html/rfc5905)
Can you try to sync your time with a Windows Client?
For that you have to modify following registry entries;
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\TimeProviders\NtpServer\Enabled = 1
Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\W32Time\Config\AnnounceFlags = 5
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 441 News and Release
- 4.3K FAQ
- 93 Security Highlight
