Log: Maximum sessions per host (1000) was exceeded (From 127.0.0.1 TO 127.0.0.1)
Hello all,
I receive loads of log messages that say that Maximum sessions per host (1000) was exceeded on a ATP200 device. Source and destination are both localhost (127.0.0.1). I know how to increase the amount of sessions, but I don't think this is normal behaviour for the firewall.
Is that resolvable?
Is that resolvable?
Hi @MStilCould you provide those log messages screenshots to me via private message?(You can navigate Web GUI: Monitor > Log screenshot it)I would like to know if those messages are normal.Thanks.0
We have the same error message on AT200.
Hi @MStil
The device will synchronize with the cloud server to keep the security signatures, NTP update, query the cloud database to have more complete security preventions. Normally the session number won’t exceed 1000. Do you have additional firewall/router in front of the device which may drop those sessions initiated by USG? Or you can enlarge(or unlimit) the session limitation on the device so that the error log won’t appear again.First, add an address object for localhost IP 127.0.0.1.
Configuration > Object > Address/Geo IP > Address > Add an address
for localhost.
Configuration > Security > Session Control > Add a session limit rule for localhost
You can enlarge” Session Limit per Host” numbers or set it to “0” unlimited.
Yes, after making this settings, these errors disappear, but others appeared
SSL traffic scanning is enabled in one rule for only one user, and his Internet access is "frozen" for different sites.
Do you use any UTM ? maybe try disabling them.
Hi @VVF
this looks different and like a memory leak. May I can help you by E-Mail? Just let me know and I´ll execute to create a Support Ticket to look into it. We can try to fix it by config change temporary and working on a solution, that it didn´t run out of memory.
Kind Regards,
Tobias0 -
Ок! Your Russian colleagues have already tortured me with requests to carry out various tests on our working equipment, but there is still no result.Can you help?
Hi @VVF
I can see the ticket and they are co-working already with a higher team as you can reach by forum.
So as soon as our development get all needed test info I´m sure we can figure out the issue and fix it.
Thanks for understanding.
Have a good weekend.
Kind Regards,
Tobias0 -
i habe a similar issue with my NAS (10.0.1.5)... this entry appears in the log even if there are very few sessions on the device (USG110)... 67 / 150000
4 2021-04-22 14:07:35 warn Sessions Limit Maximum sessions per host (1000) was exceeded. [count=85] 10.0.1.5 10.0.1.1 ACCESS BLOCK
Any Idea?
Maybe the QNAP-Cloud service?!
An issue with Custom DNS / IPv6 Prefix Delegation?!
Or a Problem with the implementation of the session counter itself...
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 299 Service & License
- 482 News and Release
