No access to email server while on SSL VPN
13»
  • Stephen
    Stephen Posts: 14 image  Freshman Member
    edited May 2018
    I have it working now, but I had to turn something off in order to make it work.
    I had a routing rule that address translation set to a specific IP.  I have five public IPs coming in. Turning that off seems to have fixed things.  That being said, now traffic from my email server is going out over the wrong IP.  Example 11.11.11.2 is the email server.  It's accepting traffic headed to 11.11.11.2, but it's sending traffic back out on 11.11.11.1.
    I suppose I just need to route the SMTP traffic?  I was having reversePTR issues before setting that rule up.  I'm assuming I'll start having that again.
    PeterUK Posts: 4,373 image  Guru Member
    So your Email server has a WAN IP?
    If you still have the routing rule I posted make sure you set the destination IP of the Email server then your other rules for sending the Email out the right IP should be fine.
    I'm having a hard time keeping track of your setup.
  • Stephen
    Yep - it's good to go now. Thanks!
