No access to email server while on SSL VPN
I have it working now, but I had to turn something off in order to make it work.
I had a routing rule that address translation set to a specific IP. I have five public IPs coming in. Turning that off seems to have fixed things. That being said, now traffic from my email server is going out over the wrong IP. Example 11.11.11.2 is the email server. It's accepting traffic headed to 11.11.11.2, but it's sending traffic back out on 11.11.11.1.
I suppose I just need to route the SMTP traffic? I was having reversePTR issues before setting that rule up. I'm assuming I'll start having that again.
So your Email server has a WAN IP?
If you still have the routing rule I posted make sure you set the destination IP of the Email server then your other rules for sending the Email out the right IP should be fine.
I'm having a hard time keeping track of your setup.
Yep - it's good to go now. Thanks!
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
