logs regarding SSL Inspection
Motivio
Motivio Posts: 21 image  Freshman Member
Friend Collector First Anniversary
What does the following log for SSL Inspection mean?
"SSL Inspection
Pass unsupported suite [server] connection. Rule_id:3"
and
"[client finished]Receive fatal alert message: desc = 48(unknown_ca) => Block/Reset SSL session!"
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @Motivio,
    When you create SSL inspection profile, there is an option for “Action for connection with unsupported suit”.
    In this case, that event was created because one of client visited a website that it doesn’t supported by your SSL inspection’s suit, because it was chosen as “pass” so traffic were passed without inspecting.
    This device connects to server but local didn’t trust CA. So it created this log output.
    Can you try to update your certificates?
    (Configuration > UTM Profile > SSL Inspection > Certificate Update > Update Now)
