Help with vlan trunk migration: Huawei -> Zyxel GS2210
Hi!
I'm new on Zyxel world and its is harder to understand the vlan conf.
I need to create vlan trunk, but can't do with zyxel.
Anyone can help with migration from huawei conf to zyxel?
Huawei:
interface Vlanif50 ip address 172.16.50.1 255.255.255.0
interface GigabitEthernet0/0/1-15, 17-24 port link-type hybrid port hybrid pvid vlan 16 port hybrid tagged vlan 1001 port hybrid untagged vlan 16
interface GigabitEthernet0/0/16 port link-type trunk port trunk pvid vlan 50 port trunk allow-pass vlan 10 16 50
interface GigabitEthernet0/0/25 port link-type trunk port trunk pvid vlan 8 port trunk allow-pass vlan 8 13 50 1001#interface GigabitEthernet0/0/26 port link-type trunk port trunk allow-pass vlan 8 50 1001#interface GigabitEthernet0/0/27 port link-type trunk port trunk allow-pass vlan 2 to 4094#interface GigabitEthernet0/0/28 port link-type trunk port trunk allow-pass vlan 2 to 4094
Huawei:
Hi, thanks to reply! I'll try this.Nebula_Adam said:Hi @DTI,
Welcome to Zyxel Community.
I help you to migrate your configuration as following:Please copy and paste to switchvlan 1normal 1-28fixed ""forbidden ""untagged ""exitvlan 8normal 1-24,27-28fixed 25-26forbidden ""untagged 25exitvlan 10normal 1-15,17-28fixed 16forbidden ""untagged ""exitvlan 13normal 1-24,26-28fixed 25forbidden ""untagged ""exitvlan 16normal 1-15,17-28fixed 16forbidden ""untagged 1-15,17-24exitvlan 50normal 1-15,17-24,27-28fixed 16,25-26forbidden ""untagged 16ip address default-management 172.16.50.1 255.255.255.0exitvlan 1001normal 16,27-28fixed 1-15,17-26forbidden ""untagged ""exitinterface port-channel 1-15,17-24pvid 16
exit
interface port-channel 25
pvid 8
exit
interface port-channel 27-28
vlan-trunking
exitPlease let us know if there is any missing configuration.
You can give me some tips about vlan trunk?
I'm confused with "normal / fixed / forbidden / tx tagging"0
Hi @DTI,
exit
pvid 8
exit
vlan-trunking
exitPlease let us know if there is any missing configuration.Adam
exit
pvid 8
exit
vlan-trunking
I'm confused with "normal / fixed / forbidden / tx tagging"0 -
@DTI,
Thanks for your reply.
Kindly provide you description as below:
For "tx tagging", selected it means tagged and unselected it means untagged for the port.Adam
- 244 Nebula Ideas
- 6.9K Security
- 808 USG FLEX H Series
- 392 Security Ideas
- Threat Watch!
- 88 Switch Ideas
- 60 Wireless Ideas
- 7.3K Consumer Product
- 333 Service & License
- 541 News and Release
- 106 Security Advisories
- 5.5K FAQ
- 89 About Community
- 124 Security Highlight
