SecuReporter Antivirus
Hello, we´re working on a Windows Server 2019 as terminal server. In the secu reporter are some blocked Viruses. Is there any possibility to get more information on a terminal server (which User, was it from an e mail or from the internet e.g...)
Hi @Michael_I,
For the source of a virus, you can find Search > Logs > Antivirus / Malware menu;
You can check Source port under this menu.
If through browser, the source port should be 80 or 443.
If through mail, the source port should be 110 or 995.
edit: Using a Atp200
Hi @Michael_I,
As far as I understand Terminal Server means Remote Desktop Protocol. Do you mean you are accessing Windows Server 2019 via Remote Desktop Protocol?
Yes, we work with thin clients via rdp on a Windows Server. Behind the Server is the zyxel. Therefore I can´t exacly see what happens, when a Virus was blocked. I want to see which user it was and if it came via email oder Browser.
Without a proxy IMVHO you cannot catch the user logged triggering the issue.
Hi @Michael_I,
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
