Help on SSL VPN with secure extender
Hi @shashank,
Can you send me the following items via private message for analysis.- C:\SecuExtenderHelper.log
- C:\Users\[windows account]\SecuExtender.log
- Startup configuration file.
Hello Cooldia,Shared the details through message and startup config file.
dear @shashankAs you know SecuExtender uses SSL on the HTTPS protocol..Simpel test to see normally if you have setup things right is that you enter the adress you normally enter in SecuExtender in your browser.Are you able to see the logon (webgui) of the zywall/usgIf not maybe you configured that intentionally, or else i think your port settings are not default.That means if you change the https port you also should add the new port in the adress tab of secuextender like : 129.129.123.12:4433
Or are you behind a NAT router possible?That means you have to port forward https to the zywall..1 -
@Mark, Thanks for the hint.
@shashank
From the log, it looks like secure extender client is unable to connect to USG. please try it again with Mark’s suggestion.
[ 2018/05/09 15:46:11 ][SecuExtender Agent][INFO] [SSL_VPN_USER_1] try to login x.x.x.x:8443
[ 2018/05/09 15:46:11 ][SecuExtender Agent][INFO] Connect to 3075629723:8443
[ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR] Cannot connect to device. 10053 (0x2745)
[ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR] Connect socket failed. (0x0)
[ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR] Failed to connect to device(1) (0x0)
[ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR] user login device failed (0x0)
[ 2018/05/09 15:46:15 ][SecuExtender Agent][DEBUG] SSL Connection is going to be closed
[ 2018/05/09 15:46:15 ][SecuExtender Agent][DETAIL] Connection ends.
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
