Help on SSL VPN with secure extender
shashank
shashank Posts: 4 image  Freshman Member
edited April 2021 in Security
We've an USG60 Security firewall
we have configured SSL VPN on the device
Client secure extender Version is 4.0.2.0
the connection was disconnecting with secure extender client continuously.
Windows 10 Operating system
  • Zyxel_Cooldia
    Hi @shashank,
    Can you send me the following items via private message for analysis.
    • C:\SecuExtenderHelper.log
    • C:\Users\[windows account]\SecuExtender.log
    • Startup configuration file.
  • shashank
    edited May 2018
    Hello Cooldia,
    Shared the details through message and startup config file.
  • [Deleted User]
    [Deleted User] Posts: 118 image  Ally Member
    5 Answers First Comment Friend Collector Fifth Anniversary
    dear @shashank
    As you know SecuExtender uses SSL on the HTTPS protocol..
    Simpel test to see normally if you have setup things right is that you enter the adress you normally enter in SecuExtender in your browser.
    Are you able to see the logon (webgui) of the zywall/usg
    If not maybe you configured that intentionally, or else i think your port settings are not default.
    That means if you change the https port you also should add the new port in the adress tab of secuextender like : 129.129.123.12:4433
    Or are you behind a NAT router possible?
    That means you have to port forward https to the zywall..
  • Zyxel_Cooldia
    @Mark, Thanks for the hint.
    @shashank
    From the log, it looks like secure extender client is unable to connect to USG. please try it again with Mark’s suggestion.
    [ 2018/05/09 15:46:11 ][SecuExtender Agent][INFO]    [SSL_VPN_USER_1] try to login x.x.x.x:8443
    [ 2018/05/09 15:46:11 ][SecuExtender Agent][INFO]    Connect to 3075629723:8443
    [ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR]   Cannot connect to device. 10053 (0x2745)
    [ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR]   Connect socket failed. (0x0)
    [ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR]   Failed to connect to device(1) (0x0)
    [ 2018/05/09 15:46:14 ][SecuExtender Agent][ERROR]   user login device failed (0x0)
    [ 2018/05/09 15:46:15 ][SecuExtender Agent][DEBUG]   SSL Connection is going to be closed
    [ 2018/05/09 15:46:15 ][SecuExtender Agent][DETAIL]  Connection ends.
