Migration from USG40 to ATP200
It seems that both models are in different product segment. You may need to set up manually.0
I answer to myselft. You can use the the migration tool and choose to migrate to ATP100, after saved the new configuration file, edit it and delete de secont line that do reference to ATP100 model. Now, you can use that file to upload to the ATP200 device0
Hi @Manel,Welcome to Zyxel community.
Thanks for information sharing. We would not advised to do so because it may have risk of lost settings. Especially migrating form different port devices and different feature model.Just in case, you may need to review and check all settings after applying configuration file to ATP-200.0
- 588 USG FLEX H Series
- 476 News and Release
