upgrade Firmware USG200
philipgoossens
in Security
Can we still upgrade the firmware on a USG200 (even if only upgrades for USG210 are available)? Can we use the USG210 firmware upgrade for it, or wouldn't it work? Currently my speed has dropped from 200 to 40 mbps what could be the reason ?
philip
philip
The USG200 support ended and you can't use USG210's firmware, is a total different platform. I highly suggest to replace it for a new USGFLEX, it's safer and faster than your old appliance. BRBest regards0
OK thank you for your answer.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
ZCNE Certified
