Zyxel USG20-VPN Cannot connect to the VPN
Nberga
Nberga Posts: 3
Friend Collector
I'am trying to configure VPN IPSEC on the Firewall but can't seem to put this to work.
My configuration:
Zyxel EThernet Lan 1 IP 192.168.1.73
Router connected to Zyxel Wan Port with Wan IP Internal 192.168.1.33
Lan1 Connected to the network switch
VPN configurations:
VPN Gateway
Interface - wan
Dynamic Address
Encryption - AES192
Authentication - SHA256
Key Group - DH14
VPN connection
Remote Access (Role Server)
VPN Gateway - The name i gave it
Local Policy - Lan1_Subnet
And That's it.
Hope it's understand
  • Nberga
    Nberga Posts: 3
    Friend Collector
    BTW
    Router has DMZ for the Zyxel.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,369  Zyxel Employee
    @Nberga
    Could you share your network topology?
    What is the firmware version you're currently using?
    As your description, the Wan interface and Lan interface are in the same IP subnet.
    Please change your LAN interface into other subnet. Ex : 192.168.10.0/24
    And make sure the VPN configuration on both site are correct.
    After change the subnet of LAN interface, if the VPN connection cannot build up.
    Please provide us the configuration of the VPN settings on both devices.
  • Nberga
    Nberga Posts: 3
    Friend Collector
    @Zyxel_Jerry
    Thank you so much for your answer.
    We already changed the Subnet, we tested the Lan2_Subnet that already is configured in the Zyxel for testing purposes.
    We've changed the port 2 to use the Lan2_Subnet.
    We reconfigured VPN settings to use the Lan2_Subnet
    So, now we have
    Zyxel WAN - 192.168.1.62
    Lan2_Subnet - 192.168.2.1
    VPN configurations:
    VPN Gateway
    Interface - wan
    Dynamic Address
    Encryption - AES192
    Key Group - DH14
    VPN connection
    Local Policy - Lan2_Subnet
    Still no connection....
  • Zyxel_Jerry
    Hi @Nberga
    May I know what is your firmware version?
    Could you share your network topology? If you have any concerns, you can private message us.
