Zyxel USG20-VPN Cannot connect to the VPN
I'am trying to configure VPN IPSEC on the Firewall but can't seem to put this to work.
My configuration:
Zyxel EThernet Lan 1 IP 192.168.1.73
Router connected to Zyxel Wan Port with Wan IP Internal 192.168.1.33
Lan1 Connected to the network switch
VPN configurations:
VPN Gateway
Interface - wan
Dynamic Address
Encryption - AES192
Authentication - SHA256
Key Group - DH14
VPN connection
Remote Access (Role Server)
VPN Gateway - The name i gave it
Local Policy - Lan1_Subnet
And That's it.
Hope it's understand
My configuration:
VPN configurations:
VPN Gateway
Interface - wan
Dynamic Address
Encryption - AES192
Key Group - DH14
VPN connection
And That's it.
BTW
Router has DMZ for the Zyxel.0 -
Could you share your network topology?
What is the firmware version you're currently using?
As your description, the Wan interface and Lan interface are in the same IP subnet.
Please change your LAN interface into other subnet. Ex : 192.168.10.0/24
And make sure the VPN configuration on both site are correct.
After change the subnet of LAN interface, if the VPN connection cannot build up.
Please provide us the configuration of the VPN settings on both devices.
@Zyxel_Jerry
Thank you so much for your answer.
We already changed the Subnet, we tested the Lan2_Subnet that already is configured in the Zyxel for testing purposes.
We've changed the port 2 to use the Lan2_Subnet.
We reconfigured VPN settings to use the Lan2_Subnet
So, now we have
Zyxel WAN - 192.168.1.62
Lan2_Subnet - 192.168.2.1
VPN configurations:
VPN Gateway
Interface - wan
Dynamic Address
Encryption - AES192
Key Group - DH14
VPN connection
Local Policy - Lan2_Subnet
Still no connection....
Hi @Nberga
May I know what is your firmware version?
Could you share your network topology? If you have any concerns, you can private message us.
- 588 USG FLEX H Series
- 477 News and Release
