How to access QNAP NAS over WAN IP
I have recently bought my first Zyxel product (USG20 VPN) and I am therefore new in the field and unfortunately do not know so well yet.
Thanks to a business contract with my Internet provider, I have a fixed WAN IP address.
Now I want to achieve the following: I bought a QNAP NAS to be able to reach my data between two locations from which I work regularly. At the location with the fixed WAN address I have now installed this NAS.
Now I want to be able to access the network drives of the NAS from the other location (without VPN).
Unfortunately without success. Therefore, I now ask here in the community.
I hope someone can help me with my problem.
With kind regards
@Bindos
Not sure which configuration you missed.
Here is a similar NAT case that can give you some reference, the only different point is that the service port is 80, not 50000:
The topology:
USG20-VPN with WAN IP: 10.214.48.47
Web server with IP: 192.168.3.33 which belongs to the DMZ zone
The purpose :
User can access http://10.214.48.47:50000 and NAT mapping to web server http://192.168.3.33:80
Configurations & Verification result:
1. Config physical P6 belongs to the DMZ zone and the web server connects to this port.
2.Check the DMZ zone setting.
3.The default DMZ setting.
4.Add a NAT setting.
In your scenario, you can change the internal port to 50000.
5.Add a security policy for NAT usage.
Following the service is HTTP(TCP 80 port), in your scenario you can create a new service object of 50000 port named as NAS_Service.
6. The browser navigates to http://10.214.48.47:50000 and can be mapped to the internal web server.
Thanks.
@Bindos
QNAP NAS are being affected for several ransomware attacks in the last months due to QTS vulnerabilities so we strongly recommend to configure a VPN SSL to have remote access to the NAS instead using a non-protected connection. Check the documentation available at ZyXEL's website.
BRBest regards0 -
+1dpipro said:@Bindos
BR
Strongly recommend, don't directly expose NAS to Internet.
Using VPN for remote access to reduce the attack surface.0
- 588 USG FLEX H Series
- 477 News and Release
ZCNE Certified
