How to access QNAP NAS over WAN IP
Bindos
Bindos Posts: 2 image  Freshman Member
First Anniversary
edited May 2021 in Security
Dear Community,
I have recently bought my first Zyxel product (USG20 VPN) and I am therefore new in the field and unfortunately do not know so well yet.
Thanks to a business contract with my Internet provider, I have a fixed WAN IP address.
Now I want to achieve the following: I bought a QNAP NAS to be able to reach my data between two locations from which I work regularly. At the location with the fixed WAN address I have now installed this NAS.
Now I want to be able to access the network drives of the NAS from the other location (without VPN).
The only changes i made where that i used the DMZ interface instead of the LAN1 interface since I have my NAS on a DMZ Port for security reasons. My local ip of the nas is 192.168.3.41 and i can access it locally. But even though I followed the tutorial step by step I can't reach the NAS via my WAN IP + port 50000.
Unfortunately without success. Therefore, I now ask here in the community.
I hope someone can help me with my problem.
With kind regards
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    @Bindos
    Not sure which configuration you missed.
    Here is a similar NAT case that can give you some reference, the only different point is that the service port is 80, not 50000:
    The topology:
    USG20-VPN with WAN IP: 10.214.48.47
    Web server with IP: 192.168.3.33 which belongs to the DMZ zone
    The purpose :
    User can access http://10.214.48.47:50000 and NAT mapping to web server http://192.168.3.33:80
    Configurations & Verification result:
    1. Config physical P6 belongs to the DMZ zone and the web server connects to this port.
    2.Check the DMZ zone setting.
    3.The default DMZ setting.
    4.Add a NAT setting.
    In your scenario, you can change the internal port to 50000.
    5.Add a security policy for NAT usage.
    Following the service is HTTP(TCP 80 port), in your scenario you can create a new service object of 50000 port named as NAS_Service.
     6. The browser navigates to http://10.214.48.47:50000 and can be mapped to the internal web server.
    Thanks.
  • dpipro
    dpipro Posts: 73 image  ZCNE Certified
    First Comment Friend Collector Seventh Anniversary ZCNE Switch Level 1 Certification - 2020
    @Bindos
    QNAP NAS are being affected for several ransomware attacks in the last months due to QTS vulnerabilities so  we strongly recommend to configure a VPN SSL to have remote access to the NAS instead using a non-protected connection. Check the documentation available at ZyXEL's website.
    BR
    Best regards
  • mMontana
    mMontana Posts: 1,461 image  Guru Member
    @dpipro "two" is considerable par to "several" for your measure?
  • zyman2008
    zyman2008 Posts: 242 image  Master Member
    50 Answers First Comment Friend Collector Eighth Anniversary
    dpipro said:
    @Bindos
    BR
    +1
    Strongly recommend, don't directly expose NAS to Internet.
    Using VPN for remote access to reduce the attack surface.
