ATP100: Keeping Lan1 and Lan2 completely separated
ChipConnJohn
in Security
Hello all,
I have an ATP100. I have Lan1 set up as my primary network. I want to set up Lan2 for IoT and have it completely isolated from Lan1.
What settings do I need to configure other than just setting up a different IP range?
I definitely don't want Lan2 to be able to access the Zyxel in any way.
Thanks,
-John
Thanks,
-John
ChipConnJohn said:What settings do I need to configure other than just setting up a different IP range?
Appropriate firewall/Security policy rules.
These rules will let you specify to your ATP100 what should do about traffic between:- LAN2 and LAN1
- LAN2 and Zywall/ATP100
- LAN2 and internet
I'd use my firewall as DHCP, mostly for allowing reservations and... denial of access. You can still configure a... wrong address for the wrong (unwanted) macaddress for not allowing TCP/IP communication.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
