lengthy USG20W-VPN Firmware update
Hi @DaveW,
It’s abnormal. The upgrade process should be done within 10 minutes.
Do you have the console log during firmware upgrading for our analysis?
When doing testing here I was on V4.31 and wanted to go back to V4.25 and the firmware update don't take so had the power it off and on which did a config reset but it loaded with the old firmware. So maybe you have to do the same and hope it loads.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
