MTU size on SYN packets
13»
    PeterUK Posts: 4,437 image  Guru Member
    edited May 2021
    But in this scenario, does the client know that the USG has changed the MSS in the client's SYN ?
    Thats beauty of this the client does not need to know as the remote end will just send smaller packets to the client and the client will happily accept them. :)
    In other words when the client sends the SYN with MSS 1460 it only thinks it can receive them size packets so making it lower is fine.
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    Hello @PeterUK
    I wonder if I have just had a lightbulb moment, after looking at https://www.imperva.com/blog/mtu-mss-explained/ ...
    In the scenario you say, when the client's MSS is modified in the client's SYN packet by the USG, are you saying that that will change the size of the segments sent by the remote end towards the client?
             - because the MSS in the client's SYN is saying what is the Maximum Segment Size (MSS) the client will accept in reception, and not the size of segments it will send.
    Similarly, if the remote end's MSS is modified in the ACK, are you saying that that will change the size of the segments sent by the client?
            - because the MSS in the remote end's ACK is saying what is the Maximum Segment Size (MSS) the remote end will accept in reception.
    Have I got it now?
    Kind regards,
         Tony
    edited May 2021
    Have I got it now?
    Yes :o
    and I tested that O2 for My 4G changes the MSS after the dongle to my server
    edited August 2021
    and with this setup by not change the MSS
    MTU size on SYN packets — Zyxel Community
    you can't get to 123.hp.com the server tries to push 1460MSS the USG sends a ICMP saying too big and the server keeps on trying without sending packets smaller.
    This is a problem.
    https://us.v-cdn.net/6029482/uploads/editor/sl/9bpiwlcmzhig.png
