IDP WHATAPP
juan_moreno
juan_moreno Posts: 2
image  Freshman Member
edited April 2021 in Security
Hi everyone,
im facing problem with my IDP on my Zywall 310
It´s block Whatsapp sending and recieving files.
How can i solve within disabling the IDP
BEST REGARDS
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,591
    image  Zyxel Employee
    Hi @juan_moreno,
    When you are sending and receiving files by WhatsApp, do you see any IDP blocking log on “Monitor > Log > Category=IDP” ?
  • juan_moreno
    Hi Cooldia,
    nop, that was the first i checked.
  • Zyxel_Cooldia
    Hi @juan_moreno,
    Can you send me your configuration file via private message. I will try it on local lab.
    BTW, I will move this post to “ZyWall VPN series”, “Security Services”  is mainly for myZyxel license related topic.
  • ChrisGer
    ChrisGer Posts: 206
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    image  Ally Member
    Hi @juan_moreno
    i've WhatsApp successfull running trough a USG with IDP ;)
    What i've done
    1. stay sure, the following Patterns are not active in your IDP Profile
    2. I've the following 3 additional ports configured on the USG to get fully connected with WhatsApp
    Port 5222-5223/tcp
    Port 3478/udp
    With this configuration, WhatsApp can be used from the LAN to the WAN (with active IDP).
    Regards & good luck
    Christian
