Option to edit admin username
Dudley_Winchester
Dudley_Winchester Posts: 22 image  Freshman Member
First Comment Sixth Anniversary
edited July 2024 in Security Ideas
To boost security of firewalls, I would like to be able to change the username "admin" to something else.
That way, a hacker would need to guess both the username and password.
This is being more commonly added to other vendors products and I welcome the option to do it with ZyXEL as well.
4 votes
Active · Last Updated
  • dpipro
    dpipro Posts: 73 image  ZCNE Certified
    First Comment Friend Collector Seventh Anniversary ZCNE Switch Level 1 Certification - 2020
    Agree! Or the ability to disable admin account...
    Best regards
    You could set the admin password to a long random thing that nothing can hack it over time and make another user with admin rights.
