Zyxel GS2200-8 don't boot
respinfo_issat_nd
I have an issue
I have a Zyxel GS2200-8 that does not boot anymore.
The sys led sys is blinking alternately.
By connecting to the serial port, here is the message in "loop" :
Exception occured!
EPC= 0x8015ED68
SR= 0x00007F03
CR= 0x50808008
$RA= 0x24A5FFFF
TLBL
Abnormal Stack Task List : NONE
/cygdrive/d/Source/400GS220024preb5/400GS220024b5/src/../src/sys_isrdep.c:185 sysreset()
$r0= 0x00000000 $at= 0x00000000 $v0= 0x80442B1C $v1= 0xB8002000
$a0= 0x80442B1C $a1= 0x0000000A $a2= 0x00000000 $a3= 0x812FDBB8
$t0= 0x8001FF80 $t1= 0x00000012 $t2= 0x00000000 $t3= 0x80F02F54
$t4= 0x80F03064 $t5= 0x00000000 $t6= 0x00000000 $t7= 0x00000000
Copyright (c) 1994 - 2011 ZyXEL sysExceptionHandler: sysTaskId()=[0x812F6F20], name=[PINI]
$s0= 0x00000000 $s1= 0x00000000 $s2= 0x00000000 $s3= 0x00000000
$s4= 0x00000000 $s5= 0x00000000 $s6= 0x00000000 $s7= 0xFFFFFFF0
$t8= 0x00000000 $t9= 0x00000000 $k0= 0x50808008 $k1= 0x80000100
$gp= 0x80E6382C $sp= 0x812FDCB0 $fp= 0x812FDCB0 $ra= 0x8007AC68
812fde90: 81 2f de 98 80 17 72 a4 02 00 7f 01 80 a5 d6 54 ./....r........T
812fdea0: ff ff ff ff 00 00 64 08 00 00 00 00 81 2f de b8 ......d....../..
Communications Corp.
��*V[ζ��#84=��ƽ6�c�
I can't reset the switch because the embeded os don't start correctly...
I don't have see any "hidden" little button on the switch.
How can I reset my switch with factory configuration ???
Help, please !
Thank you in advance !
Serge
I have an issue
Exception occured!
EPC= 0x8015ED68
SR= 0x00007F03
CR= 0x50808008
$RA= 0x24A5FFFF
TLBL
��*V[ζ��#84=��ƽ6�c�
Help, please !
Serge
Welcome to Zyxel community.GS2200-8 has a button at the right side panel, but the function is only to reboot the switch.Based on your current status, please refer to this link to resolve the event.Hope it helps.Thanks.
Zyxel_Jonas0 -
Hi Zyxel_Jonas,
I have a issue the same.
I using Zyxel MES3500. Erorr, Looping. Not load data to DRAM.
I can't go to select debug mode. And can't boot file ROM again.
Please, Can you help me?
Hi @xungbv
If you can not access debug mode of your device, it's probably a hardware issue.
Please direct to your reseller for RMA.
Zyxel_Lucious
- 441 Beta Program
- 293 Service & License
