I think I misapplied the firmware.
chriskim
chriskim Posts: 1 image  Freshman Member
edited August 2022 in Switch
After applying firmware number 470ABMH2C0.bin to GS1920-24v2 flash2, I rebooted to flash2, but it doesn't work. I didn't apply it to flash 1, but will it work if I press the reset button?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    edited June 2021
    Hi @chriskim,
    Welcome to Zyxel community!
    Do you mean you upgrade firmware and reboot but you can't bootup?
    If not, may you check is the current boot image firmware 2 or not?
    Below is the example:
    If current boot image is firmware 1, you may set the config boot image to firmware 2 and apply.
    After apply, you may reboot the switch and you may found the switch is using new firmware.
    Zyxel Melen
