Having some issues with a Port Forward
[Deleted User]
[Deleted User] Posts: 51 image  Ally Member
This should be simple, and it was, until I had to configure the rule in a Zyxel Firewall.
I run a backup from a remote web server to a local SFTP Server via port 22022.
Everything works. The locally receiving machine is a Windows and those settings are as they where before I placed the USG40 on my Lan.  netstat -an shows the port listening and there is no reason to think anything is wrong there.
On the web server, same story, everything worked for months and I have a local log file archive of thousands of successful transfers to prove that.
So when configuring a Port Forward on a Zyxel USG40 I seem to be missing something despite following the Guide that is available in the interface and despite having done some troubleshooting to find out what is wrong. As part of this I do of course check the logs, I should specifically check for MESSAGE log entries according to this: https://kb.zyxel.com/KB/searchArticle!viewBlob.action?attOid=14440 , but there are none.
The configuration looks like this:
So any hints on what may be wrong? I have not messed with the Security Policy, since this should be picked up by it and an exclusion made automagically. If it is any kind of smart.
The manual indicates another way to do this, but I am just assuming it is wrong, since there is a guide to do it in the interface.
«1
  • Ian31
    Ian31 Posts: 174 image  Master Member
    The link you post is a very old article. This is up to date one,
    https://support.zyxel.eu/hc/en-us/articles/360001390934-NAT-Rule-Configuration-on-a-USG-Port-Forwarding-
    You need to add the security policy.
    It's not automatically add allow WAN to LAN firewall rule for NAT.
  • [Deleted User]
    edited June 2021
    Ian31 said:
    The link I posted is the one referred to from within the interface. I did not look it up usin google or archive.org to find it.
    I'll read through your link and see if that works better.
    Oh, I see know. All has to be done manually. Every single rule. Old firewalls are stupid Excel sheets after all. ... ffs...
    You likely need source IP to any to have any IP connect to 192.168.1.234
  • [Deleted User]
    No, since the IP of the web host is fixed.
    So it be
    remote IP of web server > WAN IP:22022 > NAT > remote IP of web server > 192.168.1.234:22022
  • [Deleted User]
    OK, first fail log...
    Need to revise and startover...
    Maybe I missed the wan + any port > lan + 22022
    Edited out IP addresses.
  • gb5102
    gb5102 Posts: 25 image  Freshman Member
    Firewall rule should look like:
    TO: any (or whatever zone contains the 'receiving machine')
    SOURCE: <WEBSERVER_IP>
    DEST: 192.168.1.234
    SERVICE: <PORT 22022>
    ACTION: allow
  • [Deleted User]
    I know, I think I am fucking up the Security Policy part which is a first for me so I will just have to try again.
    (have been doing port forwards in different routers - D-link, Asus, Cisco - for more than 20 years, but this is a Firewall as well so more complex.)
  • [Deleted User]
    Yeah wonderful...
    2021-06-20 10:57:26
    notice
    Security Policy Control
    priority:1, from WAN to LAN1, TCP, service others, DNAT Packet, ACCEPT
    92.63.197.16:43024
    192.168.1.234:16021
    ACCESS FORWARD
    2
    2021-06-20 10:57:20
    notice
    priority:1, from WAN to LAN1, UDP, service others, DNAT Packet, ACCEPT
    141.98.10.208:5063
    192.168.1.234:5060
    ACCESS FORWARD
    3
    2021-06-20 10:57:19
    notice
    192.99.35.225:49748
    192.168.1.234:2236
    ACCESS FORWARD
    4
    2021-06-20 10:57:14
    notice
    92.63.197.16:43024
    192.168.1.234:41520
    ACCESS FORWARD
    5
    2021-06-20 10:57:13
    notice
    92.63.197.16:43024
    192.168.1.234:57040
    ACCESS FORWARD
    6
    2021-06-20 10:57:13
    notice
    92.63.197.16:43024
    192.168.1.234:4798
    ACCESS FORWARD
    7
    2021-06-20 10:57:10
    notice
    92.63.197.16:43024
    192.168.1.234:13675
    ACCESS FORWARD
    8
    2021-06-20 10:57:08
    notice
    92.63.197.16:43024
    192.168.1.234:32576
    ACCESS FORWARD
    9
    2021-06-20 10:57:07
    notice
    185.128.43.46:53024
    192.168.1.234:4400
    ACCESS FORWARD
    10
    2021-06-20 10:57:05
    notice
    92.63.197.16:43024
    192.168.1.234:19776
    ACCESS FORWARD
    11
    2021-06-20 10:57:00
    notice
    155.94.196.244:1461
    192.168.1.234:8080
    ACCESS FORWARD
    12
    2021-06-20 10:56:51
    notice
    92.63.197.16:43024
    192.168.1.234:40999
    ACCESS FORWARD
    13
    2021-06-20 10:56:48
    notice
    92.63.197.16:43024
    192.168.1.234:55375
    ACCESS FORWARD
    14
    2021-06-20 10:56:44
    notice
    92.63.197.16:43024
    192.168.1.234:52626
    ACCESS FORWARD
    15
    2021-06-20 10:56:41
    notice
    92.63.197.16:43024
    192.168.1.234:59429
    ACCESS FORWARD
    16
    2021-06-20 10:56:40
    notice
    92.63.197.16:43024
    192.168.1.234:4307
    ACCESS FORWARD
    17
    2021-06-20 10:56:40
    notice
    92.63.197.16:43024
    192.168.1.234:63759
    ACCESS FORWARD
    18
    2021-06-20 10:56:31
    notice
    92.63.197.16:43024
    192.168.1.234:38879
    ACCESS FORWARD
    19
    2021-06-20 10:56:30
    notice
    92.63.197.16:43024
    192.168.1.234:9859
    ACCESS FORWARD
    20
    2021-06-20 10:56:27
    notice
    92.63.197.16:43024
    192.168.1.234:8376
    ACCESS FORWARD
    21
    2021-06-20 10:56:27
    notice
    92.63.197.16:43024
    192.168.1.234:5481
    ACCESS FORWARD
    22
    2021-06-20 10:56:24
    notice
    92.63.197.16:43024
    192.168.1.234:1421
    ACCESS FORWARD
    23
    2021-06-20 10:56:23
    notice
    92.63.197.16:43024
    192.168.1.234:16933
    ACCESS FORWARD
    24
    2021-06-20 10:56:21
    notice
    92.63.197.16:43024
    192.168.1.234:23952
    ACCESS FORWARD
    25
    2021-06-20 10:56:19
    notice
    92.63.197.16:43024
    192.168.1.234:18574
    ACCESS FORWARD
    26
    2021-06-20 10:56:05
    notice
    92.63.197.16:43024
    192.168.1.234:6860
    ACCESS FORWARD
    27
    2021-06-20 10:56:05
    notice
    92.63.197.16:43024
    192.168.1.234:52889
    ACCESS FORWARD
    28
    2021-06-20 10:56:04
    notice
    92.63.197.16:43024
    192.168.1.234:53159
    ACCESS FORWARD
    29
    2021-06-20 10:56:02
    notice
    92.63.197.16:43024
    192.168.1.234:40172
    ACCESS FORWARD
    30
    2021-06-20 10:55:59
    notice
    92.63.197.16:43024
    192.168.1.234:40554
    ACCESS FORWARD
    31
    2021-06-20 10:55:55
    notice
    92.63.197.16:43024
    192.168.1.234:29123
    ACCESS FORWARD
    32
    2021-06-20 10:55:51
    notice
    92.63.197.16:43024
    192.168.1.234:16495
    ACCESS FORWARD
    33
    2021-06-20 10:55:50
    notice
    101.176.111.31:25619
    192.168.1.234:23
    ACCESS FORWARD
    34
    2021-06-20 10:55:48
    notice
    92.63.197.16:43024
    192.168.1.234:39891
    ACCESS FORWARD
    35
    2021-06-20 10:55:47
    notice
    92.63.197.16:43024
    192.168.1.234:21441
    ACCESS FORWARD
    36
    2021-06-20 10:55:46
    notice
    92.63.197.16:43024
    192.168.1.234:2396
    ACCESS FORWARD
    37
    2021-06-20 10:55:39
    notice
    92.63.197.16:43024
    192.168.1.234:17200
    ACCESS FORWARD
    38
    2021-06-20 10:55:39
    notice
    92.63.197.16:43024
    192.168.1.234:28094
    ACCESS FORWARD
    39
    2021-06-20 10:55:38
    notice
    92.63.197.16:43024
    192.168.1.234:6363
    ACCESS FORWARD
    40
    2021-06-20 10:55:36
    notice
    92.63.197.16:43024
    192.168.1.234:22795
    ACCESS FORWARD
    41
    2021-06-20 10:55:35
    notice
    92.63.197.16:43024
    192.168.1.234:37179
    ACCESS FORWARD
    42
    2021-06-20 10:55:31
    notice
    92.63.197.16:43024
    192.168.1.234:30807
    ACCESS FORWARD
    43
    2021-06-20 10:55:30
    notice
    92.63.197.16:43024
    192.168.1.234:36501
    ACCESS FORWARD
    44
    2021-06-20 10:55:29
    notice
    92.63.197.16:43024
    192.168.1.234:20308
    ACCESS FORWARD
    45
    2021-06-20 10:55:28
    notice
    92.63.197.16:43024
    192.168.1.234:39861
    ACCESS FORWARD
    46
    2021-06-20 10:55:27
    notice
    92.63.197.16:43024
    192.168.1.234:54809
    ACCESS FORWARD
    47
    2021-06-20 10:55:26
    notice
    92.63.197.16:43024
    192.168.1.234:61318
    ACCESS FORWARD
    48
    2021-06-20 10:55:23
    notice
    92.63.197.16:43024
    192.168.1.234:37500
    ACCESS FORWARD
    49
    2021-06-20 10:55:22
    notice
    92.63.197.16:43024
    192.168.1.234:16274
    ACCESS FORWARD
    50
    2021-06-20 10:55:21
    notice
    92.63.197.16:43024
    192.168.1.234:61748
    ACCESS FORWARD
    51
    2021-06-20 10:55:19
    notice
    92.63.197.16:43024
    192.168.1.234:36613
    ACCESS FORWARD
    52
    2021-06-20 10:55:18
    notice
    92.63.197.16:43024
    192.168.1.234:63058
    ACCESS FORWARD
    53
    2021-06-20 10:55:18
    notice
    92.63.197.16:43024
    192.168.1.234:5383
    ACCESS FORWARD
    54
    2021-06-20 10:55:17
    notice
    92.63.197.16:43024
    192.168.1.234:58846
    ACCESS FORWARD
    55
    2021-06-20 10:55:17
    notice
    92.63.197.16:43024
    192.168.1.234:23937
    ACCESS FORWARD
    56
    2021-06-20 10:55:15
    notice
    92.63.197.16:43024
    192.168.1.234:63092
    ACCESS FORWARD
    57
    2021-06-20 10:55:06
    notice
    116.117.157.69:21712
    192.168.1.234:2236
    ACCESS FORWARD
    I will be making a support ticket for this, then I can include all the details - which frankly I am not doing here, and get a better response.
  • Zyxel_Stanley
    Hi @SecCon
    May be your default policy control rule already broken then caused traffic blocked by default configuration.
    I will send you private message for further check on it.
