Hello, I need to block the local IP address on Zyxell firewall
hypnos97
hypnos97 Posts: 2 image  Freshman Member
Whats your setup like?
Are you trying to block local to internet or local to local?
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    You can add rules in security policy control. In this example, add one rule to deny the IP address 192.168.1.33 to access the internet. Follow the same way to add rule to block local to local.
  • jasailafan
  • hypnos97
    edited June 2021
    tkss
