XGS2210-52 How to enable MTU size of 9k on VLAN (resolved)
Hello @Carlsap
Actually, XGS2210-52 has MTU size with 9k between transferring traffic in original design.
You do not need to do any setting.
Ryan0 -
Thank you Zyxel_Ryan
Is there any documentation you can supply on this matter? I probably need to share this information to the HPE simplivity deployment team.
Carlsap0 -
Hi @Carlsap,Please refer to the attached file (page 2 > General > #8) for the requested information.Hope it helps.Thanks.Zyxel_Jonas0
Once again. Thank you Zyxel_Ryan for assisting.
I also found some reference to MTU size in the Userguide version 4.5 called Path MTU Table. But appearantly it only cover the IPv6. Is there a plan to include the IPv4 in this MTU table view?
Or does XGS2210 only support 9k in IPv6?
Regards from Carlsap
Tried to run ping test from telnet session of xgs2210 switch to direct connected laptop with jumboframe enabled. command used:
ping 192.168.1.100 size 1472 is ok
ping 192.168.1.100 size 1500 is not ok
Tried local loopback ping using xgs2210 local ip adress:
ping 192.168.1.41 size 1472 is ok
ping 192.168.1.41 size 1500 is not ok.
pingtest with size bigger than 1472 is not supported from telnet console.
How can I verify 9k support on this switch?
Please help ?
My mistake, I had to ping test from endpoint to endpoint. The switch itself does not reply to jumbopackets. Ran successfull ping test between two windows machines with this syntax:
ping -f -l 8972 [IP address]
Conclusion: The XGS2210 Switch supports jumbo frames on IPv4.
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
ZCNE Certified
