ATP500 config backup ready to restore on Zywall-210
Dear Zyxel Community,
Any chance to automate a complete configuration backup of an ATP500 firewall:
We need to be able, in case of disaster, to restore a firewall on the backup site with the same configurations, if we must use a new certificate then we will have to replace it on all the clients (client to site VPN) and they are several so it will take a considerable time only for this step.
If it really impossible to migrate self signed certificates from one firewall to another, should we consider to switch to a "real" certificate with certification authority?
For the point 1) I know you can schedule a backup from
Configuration > file manager > configuration file > scheduled backup
and send it through email, but I don't really like to sent it through email, is it possible to copy it using ssh (scp/sftp) --> where is stored the configuration backup on the filesystem?
The point 2) should not be a problem, we keep track of the currently used firmware, and we can download it from Download Library - ATP500 | ZyXEL if necessary to restore to a new firewall.
- overall configuration
- firmware version
- certificates
Hi @phphil
For certificate, you can export self-signed certificate with private key.
Then it will able to import to new device after entered correct password what you entered.
Current configuration backup program, it is only support to save config by SMTP or local database.
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 481 News and Release
