If running firmware fails to start correctly will a device fall back to standby firmware?
KyleW1980
KyleW1980 Posts: 1 image  Freshman Member
As the question says. If it is device specific I'm mainly curious about an ATP800 and/or USG20W.
    PeterUK Posts: 4,446 image  Guru Member
    Yes if the firmware fails falls back to the other firmware slot that may take about 10mins.
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited June 2021
    @KyleW1980
    If firmware update failed, the device will fall back to another firmware partition, and the operation time depends on your configuration. Did you face any issue on it?
