Hi @Carlos
Welcome to Zyxel Community.
You can go to Monitor > Log > View Log to check out which firewall rule blocked the whatsapp.
The forum support for English, please post in English so that other people who is interested in the same topic will be able to join the discussion.
Hi @Carlos
I remember there are several patterns to config, to enable picture download.
But be carefull, WhatsApp is a part of Facebook Inc. and require additional ports for successfull communication. It's a bit tricky to reduce the communication.
Regards
Christian
You can change the setting from your device which one you using. sometimes automatically setting puts some restriction on our application you just need to find out to make it correct.Carlos said:Como hago para descgar imagenes desde whatsapp...el firewall bloquea la descarga de imagenes desde el whatsapp
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
![2020-02-06 13_57_00-[usg210] (10.214.48.29) - .__ Welcome to 'USG210' __..png](https://us.v-cdn.net/6029482/uploads/742/KXDOMDOM136T.png)
