How to block the Ip address on Zyxel usg 60 firewall
You want security control > policy control then add a deny rule for the IP.
do you have a switch to the USG as if you do the USG can't deny IP routed by the switch.
Hi @shashank,
Configuration as below,
1) Go to “Configuration > Security Policy > Policy control” and click “add” to create a rule
2) From = LAN1
To = WAN
Source = Lan host which you want to block outgoing traffic.Action = deny
I need to block a list of IP's can it be done from a command line?0 -
@duduYou can create an address group object and move the list of IPs to this address group object.Then apply this address group object to the security policy rule.
Use the commands to create a bundle of IPs.Router> configure terminalEdit the list of IPs first and then copy and paste them all on console/ssh.address-object ip1 10.1.1.1address-object ip2 10.1.1.2address-object ip3 10.1.1.3address-object ip4 10.1.1.4address-object ip5 10.1.1.5.......1
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
