Configure Terminal Switch GS1900
3jrgrg
3jrgrg Posts: 2 image  Freshman Member
edited August 2022 in Switch
I have a gs1900 in use.
Unfortunately I can't get into the config terminal mode via SSH.
The question now is what am I doing wrong?
regards
Thomas
GS1900#
  clear       Clear configuration
  copy        Copy from one file to another
  debug       Debug Options
  end         End current mode and change to enable mode
  exit        Exit current mode and down to previous mode
  no          Negate command
  ping        Send ICMP ECHO_REQUEST to network hosts
  show        Show running system information
  traceroute  Trace route to network hosts
GS1900# conf t
Unknown command
GS1900# configure Terminal
Unknown command
GS1900#
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @3jrgrg,
    Welcome to Zyxel Community!
    GS1900 series is the Smart Managed Switch with web-based interface to manage advanced functions, so it is normal that it can't enter configure mode.
    Thanks.
    Jason
  • 3jrgrg
    Hello Jason,
    I have seen videos where the GS1900-16 were administered via SSH. Hence the question if you can unlock that.
  • Zyxel_Jason
    Hi @3jrgrg,
    User can access GS1900 series via SSH.
    However, it only allows user using some basic commands for troubleshooting like show running-config or ping, etc.
    The advance feature can be configured via WebGUI because it is a Smart(Web) Managed Switch like I mentioned.
    Jason
