USG20-VPN L2TP/IPSEC with WIndows Client
laltobelli
laltobelli Posts: 25 image  Freshman Member
First Comment Sixth Anniversary
I have set up several USG firewalls with L2TP/IPSEC to Windows Clients and most have worked with little or no tweaking.  I have set up one on a Verizon FIOS network. No matter how I adjust the settings I end up with remote server not responding errors.
Zyxel support suggested it was a FIOS issue. I worked with Verizon on the issue and they went as far are replacing the modem, nothing changed...  I have gone through the KB and have tried several of the solutions mentioned.    Some additional suggestions would be appreciated.
Thanks,
LA
The following are the log files.
165 6/14/2021 21:37 info IKE Recv:[HASH][DEL] [count=2] 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
166 6/14/2021 21:37 info IKE The cookie pair is : 0x71204fb952d2c817 / 0x2f868f00234ef22e [count=3] 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
170 6/14/2021 21:36 info IKE Dynamic Tunnel [RemoteAccess_L2TP_Wiz:RemoteAccess_L2TP_Wiz:0xa9ec625c] built successfully 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
171 6/14/2021 21:36 info IKE [ESP 3des-cbc|hmac-sha1-96][SPI 0x4043cdf5|0xa9ec625c][Lifetime 3620] 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
173 6/14/2021 21:36 info IKE [Policy: ipv4(udp:1701,98.118.57.19)-ipv4(udp:1701,192.122.55.112)] 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
174 6/14/2021 21:36 info IKE [Responder:98.118.57.19][Initiator:71.9.147.250] 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
175 6/14/2021 21:36 info IKE Recv:[HASH] 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
176 6/14/2021 21:36 info IKE Send:[HASH][SA][NONCE][ID][ID][PRV][PRV] 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
177 6/14/2021 21:36 info IKE Recv TSi: ipv4(udp:1701,192.122.55.112), TSr: ipv4(udp:1701,98.118.57.19). 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
178 6/14/2021 21:36 info IKE Recv IPSec sa: SA([0] protocol = ESP (3), spi_len = 4, spi = 0x00000000, AES CBC key len = 256, HMAC-SHA1-96, No ESN, AES CBC key len = 128, 3DES, DES, NULL; ). 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
179 6/14/2021 21:36 info IKE Recv:[HASH][SA][NONCE][ID][ID][PRV][PRV] 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
180 6/14/2021 21:36 info IKE Phase 1 IKE SA process done 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
181 6/14/2021 21:36 info IKE Send:[ID][HASH] 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
182 6/14/2021 21:36 info IKE The cookie pair is : 0x2f868f00234ef22e / 0x71204fb952d2c817 [count=7] 98.118.57.19:4500 71.9.147.250:4500 IKE_LOG
183 6/14/2021 21:36 info IKE Recv:[ID][HASH] 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
184 6/14/2021 21:36 info IKE The cookie pair is : 0x71204fb952d2c817 / 0x2f868f00234ef22e [count=3] 71.9.147.250:4500 98.118.57.19:4500 IKE_LOG
185 6/14/2021 21:36 info IKE Send:[KE][NONCE][PRV][PRV] 98.118.57.19:500 71.9.147.250:500 IKE_LOG
186 6/14/2021 21:36 info IKE Recv:[KE][NONCE][PRV][PRV] 71.9.147.250:500 98.118.57.19:500 IKE_LOG
187 6/14/2021 21:36 info IKE Send:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID] 98.118.57.19:500 71.9.147.250:500 IKE_LOG
188 6/14/2021 21:36 info IKE The cookie pair is : 0x2f868f00234ef22e / 0x71204fb952d2c817 [count=2] 98.118.57.19:500 71.9.147.250:500 IKE_LOG
189 6/14/2021 21:36 info IKE Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 256, HMAC-SHA1 PRF, HMAC-SHA1-96, 384 bit ECP, AES CBC key len = 128, 256 bit ECP, 2048 bit MODP, 3DES, 1024 bit MODP; ). 71.9.147.250:500 98.118.57.19:500 IKE_LOG
190 6/14/2021 21:36 info IKE Recv:[SA][VID][VID][VID][VID][VID][VID][VID][VID] 71.9.147.250:500 98.118.57.19:500 IKE_LOG
191 6/14/2021 21:36 info IKE The cookie pair is : 0x71204fb952d2c817 / 0x2f868f00234ef22e [count=2] 71.9.147.250:500 98.118.57.19:500 IKE_LOG
192 6/14/2021 21:36 info IKE Recv Main Mode request from [71.9.147.250] 71.9.147.250:500 98.118.57.19:500 IKE_LOG
193 6/14/2021 21:36 info IKE The cookie pair is : 0x2f868f00234ef22e / 0x0000000000000000 71.9.147.250:500 98.118.57.19:500 IKE_LOG
  • CHS
    CHS Posts: 181 image  Master Member
    edited June 2021
    The L2TP seems already built successfully.
    But client(71.9.147.250) sent delete tunnel request to server. The reason should come from your client setting.
    After building tunnel successfully, it will authenticate by your L2TP user.
    Did you configure user authentication setting in your windows L2TP profile?
    This screenshot is captured from my device.
