If running firmware fails to start correctly will a device fall back to standby firmware?
Yes if the firmware fails falls back to the other firmware slot that may take about 10mins.0
@KyleW1980
If firmware update failed, the device will fall back to another firmware partition, and the operation time depends on your configuration. Did you face any issue on it?0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
