Save System Logs to USB
Zyxel_Emily
This discussion was created from comments split from: Feature Request: Save System Logs to USB
Description:
Request 1:
Need the saving of logs in CSV or XLS format for which we will have more power to obtain the sort and filter option with the help of excel application.
Request 2:
Download all the system logs as zip in one click with checkbox to select the logs in the side of the logs row..
Currently there is an option to remove all the selected files at a time but not to download them in a single go.
Request 3:
Ability to change the saving of logs in day wise or weekly wise.
So that system logs can be saved in day wise (as currently it is saving) or weekly wise (One log file for one week, i.e. Wk1-Sep-2020.CSV or can save in the format like 01-07-Sep-2020.CSV Format).
Click like if you think the feature is useful and beneficial.
3
Thread Bumped.
When we can see such features in zyxel firewall.
Wont you think this will be really a cool feature indeed which will help security experts to better view the firewall logs???1
- 221 Nebula Ideas
- 610 USG FLEX H Series
- 53 Wireless Ideas
- 299 Service & License
- 483 News and Release
