TCP port 853 being routed to wrong interface
PeterUK
edited May 2021 in Security
USG60W V4.62
routing rules
user-incoming-- source-  destination--   Service-- next-hop --SNAT
any--vlan4093--any ---  IP192168532-- DNS--    vlan53 -----IP1921685311
any--vlan4093--any---   IP1921685312--DNS--   vlan53----   IP1921685315
any--vlan4093--any---   any-- ---------any---  -wan2-----  none
DNS service is port 53 UDP and TCP
Logs
Security Policy Control
Match default rule, DROP [count=3]
192.168.253.1:41822
vlan4093
192.168.53.12:853
vlan53
tcp
ACCESS BLOCK
192.168.253.1:40828
vlan4093
192.168.53.2:853
vlan53
tcp
ACCESS BLOCK
The next hop for port 853 should be WAN2
  • Zyxel_Cooldia
    Is this issue been there all these while? Or it only happens occasionally? And when it happens, what did you do to recover it?
    Could you send me your configuration file in PM for further checking.
    edited May 2021
    I'm not sure when this bug happened I know every time I turn the WiFi on my phone it happens port 853 is DNS over TLS.
    edited June 2021
    Its one of them things you think its wrong when in fact its correct!
    Because I have a 192.168.53.0/27 it routes to that no matter what routing rules you have unless you use Overwrite Direct Route.
    Case closed
