Jason
Configure Terminal Switch GS1900
I have a gs1900 in use.
Unfortunately I can't get into the config terminal mode via SSH.
The question now is what am I doing wrong?
regards
Thomas
GS1900#
clear Clear configuration
copy Copy from one file to another
debug Debug Options
end End current mode and change to enable mode
exit Exit current mode and down to previous mode
no Negate command
ping Send ICMP ECHO_REQUEST to network hosts
show Show running system information
traceroute Trace route to network hosts
GS1900# conf t
Unknown command
GS1900# configure Terminal
Unknown command
GS1900#
regards
Thomas
GS1900#
debug Debug Options
no Negate command
GS1900# conf t
Unknown command
Unknown command
GS1900#
Hi @3jrgrg,
Welcome to Zyxel Community!
GS1900 series is the Smart Managed Switch with web-based interface to manage advanced functions, so it is normal that it can't enter configure mode.
Thanks.
Hello Jason,I have seen videos where the GS1900-16 were administered via SSH. Hence the question if you can unlock that.
Hi @3jrgrg,
User can access GS1900 series via SSH.
However, it only allows user using some basic commands for troubleshooting like show running-config or ping, etc.
The advance feature can be configured via WebGUI because it is a Smart(Web) Managed Switch like I mentioned.
Jason0
- 3K Nebula
- 228 Nebula Ideas
- 130 Nebula Status and Incidents
- 6.6K Security
- 647 USG FLEX H Series
- 357 Security Ideas
- 86 Switch Ideas
- 55 Wireless Ideas
- 7.1K Consumer Product
- 304 Service & License
- 496 News and Release
- 93 Security Advisories
- 5K FAQ
- 89 About Community
- 110 Security Highlight
