Auswirkung der Einstellung "Wand-/Deckenmontage" am WAX610D
Hi @Motivio
Like you mentioned, the antenna type of WAX610D is dual-optimized antenna, allowing AP to be mounted on the wall or on the ceiling.
The antenna pattern of wall-mount focuses energy to the front end which can cover longer distance but signal outside of the patter will be weaker.
If you want to let the signal be good in a not huge area, deploy as ceiling-mount will have better coverage.
Thank you.
Regards,
Bella
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
