AP firmware download failed. Reason: Device storage is not enough..
I cannot open the console because the certificate issue.
But I've maybe found another solution, I've manual uploaded the new firmware on "Firmware Package", now I've:
V4.15 - Running
V4.31 - Standby
How could I run the V4.31? I'll not lose my settings?
Thanks.0 -
Hi @Wilson_ks,
Issue had been solved by remote checking, it is okay now.
You can upgrade to V4.3X directly on partition 1.
Hello!
I have same problem. USG 60w -- AP Firmware download failed. Reason: Device storage is not enough..
Auto Upgrade disabled.
How to fix it?
Thanks.
Hi @c7ic
Can you upgrade USG firmware to 4.33WK19 first.
ftp://ftp.zyxel.com/USG60W/firmware/433AAKZ0ITS-WK19-r88384.zip
And try to enter this command to flush memory.
Router> debug system _disk-cleanup
After cleared memory, and try to download AP firmware again.
- 588 USG FLEX H Series
- 476 News and Release
